remove point parameter (position) from flip action - flip only
attribute, not point parameter
On 2010.02.14. 19:53, perry59 wrote:
> I am trying to create a "simple" DB, a variation on a callout block. Its just a simple oblong border around an attribute with a "leg" on one end.
> I want to be able to stretch the leg and stretch the border (to accomodate different lengths of text). I also want to be able to turn the border off if desired and to flip the object along a vertical axis.
> So far it all works just peachy, I can turn the border on/off, stretch the leg or the border (and the text stays centered in the border) and flip it.
> Just one thing is screwy. If I flip it, the text flys out of the border. If it flips multiple times the text gets further away. I chained the position of the attribute to the stretch action on the border (or I thought it was chained to only the stretch action) to keep it centered, but it looks like it is also chained to the flip action.
> Thats where I am confused, when you "chain" an action is it chained to just the previous ONE action, all previous actions, or ALL actions previous and post? Does it make a difference at what point in the DB construction you mark an action as chained?
> I have attached a copy of the file, if someone could clear this up for me I'd appreciate it!
> Edited by: perry59 on Feb 14, 2010 5:52 PM
