Dynamic Blocks
Distinguished Contributor
Thomas.l
Message 11 of 23 (421 Views)
Re: Bolt with nut
04-25-2012 10:09 AM in reply to: c-wych
Is this what you need?
Active Member
c-wych
Message 12 of 23 (417 Views)
Re: Bolt with nut
04-25-2012 10:48 AM in reply to: Thomas.l
Kind of.  I want to be able to change the length of the bolt also.  So its really a combination of the last two files.
ojuris
Message 13 of 23 (410 Views)
Re: Bolt with nut
04-25-2012 12:53 PM in reply to: Thomas.l
may be something like that?
Active Member
c-wych
Message 14 of 23 (407 Views)
Re: Bolt with nut
04-25-2012 01:45 PM in reply to: ojuris
That works except I also was hoping for the ability to have a hidden line between the head of the bold and the nut.  But other then that, its perfect.  Thanks.
ojuris
Message 15 of 23 (404 Views)
Re: Bolt with nut
04-25-2012 02:18 PM in reply to: c-wych
try this
Active Member
c-wych
Message 16 of 23 (401 Views)
Re: Bolt with nut
04-25-2012 02:32 PM in reply to: ojuris
That works.  And it seems so simple.  :smileyhappy:  Thanks for the help.  I don't know why it didn't work when I tried it, atleast now I can look at it and see how it works and expand my AutoCAD knowledge more.
Active Member
calteq
Message 17 of 23 (343 Views)
Re: Bolt with nut
06-20-2012 04:06 AM in reply to: c-wych
Here's another
Valued Mentor
RockyBrown4134
Message 18 of 23 (307 Views)
Re: Bolt with nut
07-24-2012 10:09 AM in reply to: calteq
Here's another
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
Sam Carbis Solutions Group
AutoCAD 2012 / Inventor 2012
New Member
dcasciato
Message 19 of 23 (42 Views)
Re: Bolt with nut
10-08-2014 11:10 AM in reply to: ojuris
This is the type of drawing block I am looking for. A couple of things - this is still Metric. The question and what I am looking for is a ANSI (Imperial) drawing. Also looking at the properties you specify the "Grip" distance. How do we streach this bolt, i.e. change the grip dimension?
Thanks - DJC
New Member
dcasciato
Message 20 of 23 (38 Views)
Re: Bolt with nut
10-08-2014 11:21 AM in reply to: RockyBrown4134
I like your block - couple of things. When opening the Block - I am told there are "Authoring Elements" and optioned to open in "Block Edit Mode".
On screen I see the definitions of dimension. Thinking this can be modified for my desired bolt diameter and grip thickness... can't understand how to change these elements. Help please or feel free to point to a YouTube video.
Great Job - DJC
