Hi, I have a problem ... I'm working on a file with more hiperlink add to blocks in AutoCAD. I need to export the layout in PDF whit the blocks and the attribute (link) . When i print in PDF the information about the Hiperlink I lose the connection at URL. There is a solution for this?? It's possible to print in PDF a file in DWG and keep the link??
Thank you
