Dynamic Blocks Forum
Block with field doesn't work if paste from Tool Pallet
12 REPLIES 12
Message 1 of 13
kjdrafting
807 Views, 12 Replies
I have problem with attached block (also with other similar blocks with field). This block include field in block attribute. Works fine if I copy and paste this block. When I drag and drop from Tool Pallete field disappeary. Is it any way to fix this problem?
Chris
12 REPLIES 12
Message 2 of 13
Charles_Shade
in reply to: kjdrafting
What happens if you drag the Block from the Palette and then Explode it?
Message 3 of 13
kjdrafting
in reply to: Charles_Shade
Just exploded, like typical... I get my geometry and attributes.
Message 4 of 13
Charles_Shade
I wanted to make sure that it was not a nested block.
BTW - The Field stays visible when dropped from the Palette here.
Message 5 of 13
ojuris
May be You can try make new block, when You insert Your block. That new block include in tool palette and there for that block define to explode that block, when insert from tool palette
Juris
Message 6 of 13
kjdrafting
Nope. No field when drop from pallete, just value of field. I think problem is field refer to object and I don't know why when drop from pallet the new block is like a new object.... something like that...
Message 7 of 13
steven-g
Thats the problem. A block cannot refer to itself when it is inserted. Copying works fine
Message 8 of 13
ojuris
Try another block
Juris
Message 9 of 13
kjdrafting
in reply to: ojuris
works fine! thanks! what did I wrong???
Message 10 of 13
ojuris
I create field in block editor space, not in drawing space
Juris
Message 11 of 13
kjdrafting
in reply to: ojuris
Thanks a lot!
Message 12 of 13
Charles_Shade
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Message 13 of 13
steven-g
in reply to: ojuris
Thankyou. This is a WOW moment. My working life has just been made so much easier.
”Boost
”Tips
”Services
