Show only
Search instead for
I have many blocks with text inside. is there any way to change only the text height when i insert the same in different drawing scale???.
moiz
If you want it done automatically, then you will need some lsp. However, if
you don't mind an extra click when it's inserted, then I would do it with a
lookup and a scale action. (See attached)
Thanks for the reply.
lookup & scale action will not be useful since i have many texts inside the block.and i have different blocks with different text height which will be inserted in one drawing. Actually i am looking for some code to change the text height automatically.
thanks
moiz
Here's the code to change the width factor of text and attributes in a block definition.
You'll need to modify it slightly to change height (the dxf field for widthfactor is 41; height is 40).
