Dynamic Blocks Forum
Block properties table labeling
1 REPLY 1
bgingerich
406 Views, 1 Reply
So I made a DB for shcs's, but now I want to know if it is possible to rename the lengths to our company's part numbers?
Brandon Gingerich
1 REPLY 1
AcadAdamLT
in reply to: bgingerich
From my knowledge, no. There is no way to rename the listed options in blockproperty tablet.
Something to wish for maybe.
If your in desperate need of it you could probably archieve it with a a lookup since there you can name every option. But you would not have the pulldown menu under each nominal size. You'd have to make one option for each combination of size and length.
As far as my knowledge goes, best of luck
// Adam
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
”Boost
”Tips
”Services
