Dynamic Blocks Forum
Block problem
5 REPLIES 5
529 Views, 5 Replies
Block problem
In my made block i have next items:
_ClosedBlank
_Oblique
Deugel
How can i remove these?
I did not use them but they keep coming up in my commandline when i insert my block with vba. I need to get these out of my block.
 can somebody please help me?
thanks
5 REPLIES 5
ojuris
hi!
the first 2 is associated with dimensions - they automatically add in file when you use dimensions
third block I think is not standard block and you use it somewhere in your drawing
and why you think that they are in your block?
in the list you see name of all named blocks in your file
Regards
Juris
in reply to: ojuris
When i insert my block with vba i get in my commandline:
"Deplicate definition of block _oblique ignored."
But when i use my vba program i insert more then 20 blocks in the drawing. But i get it with every block so my program is slowed down. I need to fix this.
in a early version of the block i used "deugel" but i need to get it out ..
I don't know how to fix this ..
Can you help me?
Sorry my english is not that good,
kasperwuyts
The _oblique block is nothing more than the standard diagonal line you use on your dimension lines. If you explode a dimension line, you can select this block. So you are obviously adding blocks that contain dimensions. The block definition message always happens when you paste a dimension line in your drawing or import a block containing one. Are you sure this message is the cause of the slowness?
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
ojuris
may be post some of your block
in reply to: ojuris
I am not sure if this slowed my program down. My laptop is 4 years old, maybe thats the problem? But in the beginning of the week my program runned fast and good. But my pc crashed. And now it goes slower and slower...
Thanks for response
This is one of the 100 blocks :
”Boost
”Tips
”Services
