Hello, I am experimenting with Annotation, trying to create annotative blocks with dynamic properties. I am having trouble with including attributes in the blocks. Basically the problem is when I modify the dynamic parameters of the block and change the scale (and annotative scale) of the viewport then the attribute gets moved out of position - the size of the text scales properly with the annotative scale, but the text position gets moved considerably out of the proper position.
Attached is an example of the problem - an annotative dynamic block of a grid bubble. There is a basepoint parameter set along the circle and a rotation parameter justified to the center of the circle. The rotation parameter is suppose to rotate the basepoint so then the block can be scaled out from the basepoint regardless of its location along the bubble.
THank you for any help anyone can offer!
You've done all the usual things. Attrib is Locked and not Annotative.
The Block is Annotative as it should be.
Not sure why it is buggy for you but I do not use Annotation.
There are some here who do who will chime in. Also try the Forum Search and see if someone else may have encountered this before.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
