Dynamic Blocks Forum
auto-number array in dynamic block
20 REPLIES 20
Message 1 of 21
amosweing
11684 Views, 20 Replies
hi i"m trying to create a dynamic plan-staircase with step numbers the stairs are added by an array command and i could count the total number of stairs by dividing the total distance by width of step. but i want a number on each step ! (using autocad 2014)
20 REPLIES 20
Message 2 of 21
amosweing
in reply to: amosweing
did it!
Message 3 of 21
Libbya
Very cool.  Thanks for sharing.
Message 4 of 21
I was looking at the block you created, but I do not really understand how you got the counting working. Could you maybe give a brief explaination? I see you created two Attribute Definitions but how are they related? Thanks!
Message 5 of 21
steven-g
Here is a simplified version just containing the count. It uses a nested block and a blocks ability to give its position within another block, the number is found using a simple field formula. The array distance is used to work out the number.
Message 6 of 21
in reply to: steven-g
The 'fields' and the use of them were new to me. I can get it working now, thanks!
Message 7 of 21
jarredmonday
I came across this post and thought I'd give it a bump. I made this for our department so we can save some time. it's not too complicated.
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Message 8 of 21
lenaluchenta
Could you please explain the field process which you used? Im trying to make xfmr's that are number on there own if you stretch the dynamic block but I cannot get the numbers to change.
Message 9 of 21
ojuris
in reply to: lenaluchenta
hi
there is nested block with attribute
attribute fave field with formula    object (circle) center X coordinate  divided by  array column offset value
Message 10 of 21
lenaluchenta
in reply to: ojuris
Thanks, I will give that a try.
Lena Luchenta
Message 11 of 21
lenaluchenta
in reply to: ojuris
Hi I tried the field directions but did not get anywhere as I have a rectangle and that is a circle. Is there anyway you could take a look at it for me and let me k now if it can be done?
Message 12 of 21
ojuris
hi!
try attachment
Message 13 of 21
lenaluchenta
in reply to: ojuris
Thank you. You make it look so easy. How do you know what formula to use?
Message 14 of 21
ojuris
hi!
Yes, it is not difficult, it is the simply arithmetic
You must think mathematically after use grips where will be nested block (it's base point coordinate) and what formula you must use to get necessary result
If you don't understand - ask - I'll try answer
Message 15 of 21
lenaluchenta
Thanks for all your help.
Lena Luchenta
ELECTRICAL DESIGN ENGINEER
lena.luchenta@westwoodps.com
Direct (480) 840-7708
Main (480) 747-6558
Cell (480) 392-1000
Westwood Multi-Disciplined Surveying & Engineering
6909 East Greenway Parkway, Suite 250 | Scottsdale, AZ 85254
________________________________
westwoodps.com
(888) 937-5150
Message 16 of 21
tgros
in reply to: ojuris
I can't see any formula in the attribute field ? Where is it ? (The block is working as expected).
Message 17 of 21
nileshk
can u pls show steps how u do this in block
Message 18 of 21
mehran.alone.20
How can  I make this ?
  1. Can you send me tutorial about that, please ?
Message 19 of 21
mehran.alone.20
in reply to: nileshk
Message 20 of 21
iciubotariu
”Boost
”Tips
”Services
