Dynamic Blocks Forum
AttSync of blocks - takes a long time with numerous objects
1 REPLY 1
JanYoder7484
1947 Views, 1 Reply
The AttSync command does what it advertises fairly well.  My problem is that I have thousands of small blocks in a single drawing.  (My current drawing has 2100 block references with four attributes in each one.)  I may change the attribute values in a few of them and need to re-sync the attribute locations.  When I run AttSync it updates every single block insertion.  One of two things are desired:
1)Flag each block insertion as having been sync'ed, reducing the number of objects requiring synchronization when AttSync is called again.  Provide a way to force all to be sync'ed.
2)Allow a selection set in the AttSync command after selecting the block to sync.
Either or both of these would a great time-saver for those of us with large numbers of blocks with attributes.
1 REPLY 1
AcadAdamLT
in reply to: JanYoder7484
To attsync all blocks
Attsync;name;*;
; = Enter
You can either use it as a macro or as a command. Attsync iniates the command which will promp you:
"Enter an option [?/Name/Select] <Select>".
Here you choose name, and when it promps you:
Enter name of block to sync or [?]
You choose * to do a wildcard match, wildcard match on nothing equals everything.
Simplified:
Attsync
*enter*
Name
*enter*
* (wildcard)
*enter*
To make a "selection set" is not possbile, but you could cheat it with a macro. To do so you would need a macro that repeats itself, this macro below would do the trick.
^C^Cattsync;select;\YES;
This macro will, when iniated promp you to "Select a block:" when you click your block it will sync it and end the command. Now to simulate multiple selection you stack the macro upon itself several times. for example:
^C^Cattsync;select;\YES;^C^Cattsync;select;\YES;^C^Cattsync;select;\YES;^C^Cattsync;select;\YES;
It's a cheaptrick but it does it's work, you can stack the macro up to a hundred or so to be sure you don't have to re-iniate the macro in the middle of attsynching.
To simply end the command press esc and the command will end, for each time you select a block it will update it's attributes.
Hope it helped
//Adam
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
”Boost
”Tips
”Services
