I AM HAVING THE SAME ISSUE, DID YOU EVER FIND A SOLUTION?
wrote in message news:5129979@discussion.autodesk.com...
I have a created a Dynamic Block with a number of visibility states. When
everything is visible and I open the enhanced attribute editor, the prompts
are correctly aligned with the tag names. But when I change to a different
visibility state, the prompts do not match the tag name of the attribute.
Editing the value of the attribute results in a correct display in the
drawing, but the prompts in the EAE are still incorrect for some tag names.
Opening BATTMAN shows all the prompts correctly aligned with the attribute
tag. HELP...I can't seem to get this one figured out
