I have a dynamic block where I want to move an attribute along with lines, rectangles etc.... The most noticable problem is that when I chose the attribute as part of the move action, I got an error "1 unlocked AttDef filtered from selection". After some research I found that if I locked the attribute, I didn't get this error when I selected it.
So far so good, or so I thought. When I tested the block, the attribute moved as expected. However when I closed down the block editor and tried it again, the attribute doesn't move and the attribute grips are suddenly showing!! This did not happen when testing the block.
I decided to add an additional attribute. The second one does not even show in the Enhanced Attribute Editor.
Can anyone assist with either of these issues?
