Dynamic Blocks
Dynamic Blocks
Active Contributor
0 Kudos
Post 1 of 10
array multiple objects sequentally
576 Views, 9 Replies
09-28-2012 07:40 AM
Greetings,
It seems like this should be easy but it's not. I have a block with multiple components. I want them to array sequentally as I drag the grip. First one component, then the next, then the next. What I get is all 3 at once when I drag the grip far enough. I tried 3 seperate linear parameters with their grips stacked but that didnt work either. What I have attached is a very simplified version of what I want, but I think once I get the concept it will be easy to elaborate on.
Thanks in advance,
Dave
is it what you want?
Juris
Valued Mentor
69 Kudos
Post 2 of 10
Re: array multiple objects sequentally
09-28-2012 08:31 AM in reply to: ddepriest
Juris
Active Contributor
0 Kudos
Post 3 of 10
09-28-2012 08:36 AM in reply to: ojuris
That is perfect. Thank you very much!
Valued Mentor
69 Kudos
Post 4 of 10
09-28-2012 08:37 AM in reply to: ddepriest
You`re welcome
Distinguished Contributor
0 Kudos
Post 5 of 10
11-13-2012 01:54 AM in reply to: ojuris
Juris,
I would like to know how did you do it?
Thanks.
370 Kudos
Post 6 of 10
11-13-2012 05:01 AM in reply to: jz4all
Distance1 is the Parameter that Stretch, Stretch1, and Stretch2 are linked to.
Stretch controls the Distance4 Parameter that is chained to Distance1. Meaning that when Distance1 is activated the Action that is linked to Distance4 will also activate. Tha Arrays are linked to the relevant Parameters and logical distances were assigned. The circle needs to move 800 units to get to its first position, etc...
The rest of the Parameters and Actions are similarly setup.
(I just hope Juris had to trial and error this and did not just do it in one shot. I might have to not like that guy anymore if he did. :smileyvery-happy:)
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Active Contributor
0 Kudos
Post 7 of 10
11-13-2012 06:32 AM in reply to: ddepriest
As a Post Script here is the block that I was actually working on. It took quite a bit of trial and error, and i still don't understand why the distance parameters have to be set to the lengths that they are.
Valued Mentor
69 Kudos
Post 8 of 10
11-13-2012 06:48 AM in reply to: ddepriest
may be You can save to 2012 version?
In this moment I can`t have 2013 version
Regards
Juris
Active Contributor
0 Kudos
Post 9 of 10
11-13-2012 06:50 AM in reply to: ojuris
Sure, no problem.
0 Kudos
Post 10 of 10
11-14-2012 02:57 AM in reply to: Charles_Shade
Thanks a lot Charles :catvery-happy:
