Can the column spacing of an Array within a dynamic block be defined in a lookup table? I have several dynamic blocks in which a linear stretch of an array produces the repeated elements at the column spacing set when the array was created. However, I have the need to use a lookup table to change the array's column spacing.
jmcinnis
You can do it with visibility states. See attached.
In that file is a separate circle, chained linear parameter and array action for each of the states. There is one stretch action as master over ALL.
