DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
XREF Control
6 REPLIES 6
thomk
17063 Views, 6 Replies
XREF Control
Is there a way to manually call up the XREF dialog box?
The 2012 version does not appear to allow you to call it up.
When loading a file that has an xref issue, the pallette will appear if the user tries to resolve the XREF issue.
Thank you,
t.k.
6 REPLIES 6
Zeinab1985
in reply to: thomk
From application menu , type xref in the search command field as shown in attached screenshot.
thomk
in reply to: Zeinab1985
Thank you!
I hadn't noticed that's what that field was for.
Thank you again!
in reply to: thomk
you are welcome.
whitney_jeff
My XREF palette disappeared and typing XREF does not start it,  I have not been able to find anyway to bring it back - any help would be appreciated!
I am right now stuck using the classic version dialogue box which is clunky at best 😔
whitney_jeff
in reply to: pendean
Got it!
Thanks Dean
