DWG TrueView
New Member
0 Kudos
Post 1 of 5
Unit of measure
7238 Views, 4 Replies
12-28-2010 11:17 AM
The drawing that I am viewing using DWG TrueView provides dimension in feet and inches when measure objects.  Is there a way to have the measures provided in metric / millimeters?
New Member
0 Kudos
Post 2 of 5
Re: Unit of measure
11-25-2011 04:10 AM in reply to: rjaneiro
over 300 hundred views and no replies. I guess there is lots of interest, but no solution.
toad
*Expert Elite*
1,593 Kudos
Post 3 of 5
Re: Unit of measure
11-28-2011 05:10 AM in reply to: toadoftoadhall
The file creator controls all aspects of the file: not much you can do in the viewer except view it as created.
To change units, the file must be scaled first, unless you want to endlessly do the math: AutoCAD works with "units", a generic measurement that can be inches, mm, meters, or even lightyear and are not interchangeable with a button or switch. The file creator, or anyone able to change the file (not the viewer) must scale to redefine "units".
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
0 Kudos
Post 4 of 5
TrueView Unit of measurement
05-14-2013 05:54 AM in reply to: rjaneiro
Is there any possibility to see in viewer which are the units the measurements are done (cm, inch, m, etc)? Thanks
*Expert Elite*
1,593 Kudos
Post 5 of 5
Re: TrueView Unit of measurement
05-14-2013 06:05 AM in reply to: sorpic
Measure a known distance and compare it with what the program reports.
Post to the Community
New Post
