DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Unable to install DWG Trueview in Windows 8
14 REPLIES 14
Message 1 of 15
7292 Views, 14 Replies
I have done a search and unable to find the answer specific go my problem.
I have downloaded DWG trueview 64bit to my download folder. Right click and hit open.....nothing happens......Try to delete the exe file and get an error File in Use "The action can't be completed because the file is open in SetupDWGTrueView2013_64bit.exe"
Whats up.?
Running Windows 8
Architecture 2009
CPU HP Pavilion AMD proc
Thank you for comments and suggestions.
JSdraft
14 REPLIES 14
Message 2 of 15
Restarted machine.
Downloaded the 32 bit file this time and it seems to have worked except now it hangs up on initializing with a "The system cannot open the device or file specified"
now what?
Message 3 of 15
pendean
Windows 8 is not currently supported.
You might have luck trying something like this:
http://www.cadforum.cz/cadforum_en/how-to-install-autocad-2013-and-inventor-2013-in-windows-8-tip903...
Message 4 of 15
brett
in reply to: pendean
Does this apply to DWG Trueview 2014?
I am trying to install on a Windows 8 Pro 32bit Dell Latitude Tablet.
When trying to open a drawing is says it's missing a diplay driver (.hdi) in the \drv\ directory.
Brett
Message 5 of 15
pendean
in reply to: brett
It should for 2014 version, but it's not officially listed (or I can't see it):
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
Can you post a scrneeshot of the exact error?
Message 6 of 15
I have this problem too.
Message 7 of 15
that's dwg trueview 2014 also
Message 8 of 15
brett
portt, thanks for posting the screen shot.  I hadn't gotten around to it yet.  That's exactly the same message I'm getting.
Message 9 of 15
same Problem here with the Dell Latitude Win 8 Pro.
A display driver file .hdi is missing or has been corrupted when i want to open a file.
Someone can help?
Message 10 of 15
After a while i resolved the Problem with Win 8 Dell Latitude and TrueView 2014.
1. Open "Regedit"
2. search for "CustomHeidiDriverPath"
they are two of them in the Registry. Delete both on the right side.
And it works fine 🙂
Message 11 of 15
I just want to double check:
  • The advice is to use Registry Editor to delete a couple of files from my registry
  • This advice comes from a user with only two posts
  • The user's name is "fakerr"
Just checking...
Message 12 of 15
Good Morning,
it worked fine for me. Sorry for my Nick but i'm using it allmost everywhere 🙂
If you worry about. Just Save the Registry before.
Regards
Message 13 of 15
rowlandhill
Just to confirm it worked great for me on a Lenovo Win8.1 Pad.
many thanks
Message 14 of 15
I have a Windows Surface 2 tablet that has all the reqirements to run Trueview 2014. I download 32bit which is whats required and i save it but i get the message that it is not able to run on this pc. I also looked into the Regedit and could not find this "customheididriverpath" Am i missing something with this tablet that im not aware of. All I want to do is run trueview 2014.
Message 15 of 15
tcombs
Worked for me. I have a Dell Latitude10 tablet and had the same issue.
