DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Turn Plot Overwrite Warning Prompt Back On
3 REPLIES 3
Chowbacca
574 Views, 3 Replies
How does one turn the plot overwrite option back on as shown in the screenshot attached?
3 REPLIES 3
nhubbard
in reply to: Chowbacca
I am also looking for the answer to this.... anyone have any ideas?
Thanks.
pendean
in reply to: nhubbard
m_latz
This setting is stored in:
C:\Users\<username>\AppData\Roaming\Autodesk\DWG TrueView 2015 - English\R13\enu\Support\Profiles
in the file: FixedProfile.aws
There remove the section for:
<HideableDialog id="AcPlotGui.PlotFileExists" title="Plot - Plot File Exists" category="Plot" application="" result="6"><Preview><TaskDialog Source="/AcTaskDialogs;component/TaskDialogs.xaml" Id="AcPlotGui.PlotFileExists" xmlns="clr-namespace:Autodesk.Windows;assembly=AdWindows"/>
As alternative you can also delete the whole roaming folder structure from TrueView and the registry section:
HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R13
This starts the 2nd stage windows installer service which restores the original files.
regards
Markus
