DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
turn off LAYLOCKFADECTL
3 REPLIES 3
SteveChestnut
1735 Views, 3 Replies
In DWG TrueView 2013 the default setting for LAYLOCKFADECTL
must be somewhere around 50.
We'd like to see all layers at full capacity and not faded including the locked ones.
Is there any way possible in TrueView to set LAYLOCKFADECTL to 0.
Thank you,
Steve
3 REPLIES 3
rkmcswain
in reply to: SteveChestnut
You can edit this in the registry.
Make sure DWG Trueview is not open
Go to:
HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R10\dwgviewr-Bxxx:xxx\Profiles\<<Unnamed Profile>>\Drawing Window
Create a DWORD (32bit) value named "LayLockFadeCtl" and set the value to 0.
Launch DWG Trueview and test.
SteveChestnut
in reply to: rkmcswain
Thank you so much for your detailed answer.
I just tried it and it worked just like you said.
Thanks again and have a good one.
Steve
rkmcswain
Glad it worked. It's a shame that those settings are not exposed in the UI.
