DWG TrueView
DWG TrueView
Member
senthamt
Message 1 of 2 (611 Views)
Truview 2014 Layer control (Turn On\Turn OFF) programmatically
611 Views, 1 Replies
03-06-2014 11:22 PM
I'm using Volo Viewer Control to display some DWG files, these files have multiple layers, the application is an older VB6 app (that use VoloView, but have to be upgraded).
Question:
It is possible to turn off, at runtime, a Layer?
In VoloView i do something like this:
AvViewX1.LayersOff = "LIMITES"
How can I do the same with DWG TrueView?
Can I list all the Layers (using a collection, for instance) that a DWG contains? And turn it ‘off’ or ‘on’?
dgorsman
Message 2 of 2 (566 Views)
Re: Truview 2014 Layer control (Turn On\Turn OFF) programmatically
03-11-2014 01:47 PM in reply to: senthamt
There is no programmatic/scripted controls in TrueView.  There is the standard layer palette, and layer filters and states should still be available provided they were set in the DWG file.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
