DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Trueview Problem -- "FATAL ERROR - Out of Memory "
2 REPLIES 2
2078 Views, 2 Replies
I need to open a dwg and just downloaded Trueview. It crashes with a Out of System Memory message at 81% and never opens the document. The dwg file is 190 M. I looked up the problem here and see the solution of clearing the Autodesk cache. I did that, but it did not help.
I have a 32-bit system (Win7) with 4G ram, which is the max. Does that mean I have to go to a 64-bit sytem?
Thanks,       Joel
2 REPLIES 2
pendean
Yep, time to upgrade assuming your file is not corrupt.
Yes, I took care of the problem. I went 64-bit and doubled my ram with a new computer. It works fine now!
