Anytime I export to DWF of PDF I get a message "DWF application not found". Stating it can't find DWF viewer and provided Design Review download.
What make this interesting is I have Design review installed and Acrobat Pro. With both DWF and PDF they preview just fine in their respective programs. I get this message for PDF export too, even though it's not a DWF. To add to the strangeness, if I turn off Preview for either export the message still appears, but the exported files do not preview as requested.
The only way I've been able to turn it off is through the "Preferences" dialog. The only preference option is to turn off preview for DWF. However, if I restart Trueview the message(s) return and I've not been able to identify a registry setting to control this. It's not really and issue, just annoying.
Thoughts?
Chris
What version of TV do you have?
What version of ADR do you have?
Did they both come from the same single download of ADR?
OP:
"Anytime I export to DWF of PDF I get a message "DWF application not found". Stating it can't find DWF viewer and provided Design Review download."
Hi @SeanMacOz
This is working fine for me in DWG Trueview 2016 and opens in ADR 2013 when exporting. Have you tried both Export and Printing options for DWF. If so, you might want to check your Printer Support File Path settings in the options for DWG Trueview 2016.
Might be worth checking your device driver file search path as well.
Also as previously suggested, make sure ADR 2013 is installed correctly (try a repair) and that the DWF format is defaulted to Autodesk DWF Application.
Duncan
