Disregard this post. You are using DWG TrueView, not Autodesk Design Review.
"Scott Sheppard (Autodesk)" wrote in message
news:5350538@discussion.autodesk.com...
http://dwf.blogs.com/beyond_the_paper/2006/08/index.html
I believe ADR uses DirectX 9.
wrote in message news:5350526@discussion.autodesk.com...
I am trying to install TrueView 2007. Is there anyway to make this run in
SILENT mode? You run Setup.exe and it will install MDAC, DirectX, Net
Framework and then DWG all without any interaction?
If not here is my problem. I have broken down my install into 4 seperate
installers.
1. Net Frame work (this works)
2. MDAC (this works)
3. DirectX 9
4. DWG 2007
I have installed DirectX 9 and 10 but DWG will not install. And if I re-fun
the Setup.exe it will reinstall DirectX even though I have alrady run it.
Any anyone seen this and how do you get around it?
What is the Setup.exe doing that it trys to install DirectX 9 when version
10 is already there?
Thanks.
