I'm using DSD files i created with Trueview 2010 and loaded the same DSD in TV2013 and nothing happens. I can print individual PDFs, but a group of them. The command line afterwards say _publish repeatedly but no PDF is created...I tried selecting a DWF as the output, and same thing happens. i tried manually adding files (to be sure the DSD wasn't the problem) and i get the same -lack of- result...
thoughts?
i went through the Plotters folder that is setup as default, and the DWG to PDF.pc3 file had been renamed to DWG to PDF 11x17.pc3. I renamed it back and it's working fine.
