The "Measure" tool for "Distance" works perfectly well, however, when I click on "Measure" "Area" it is not calculating correctly. (Ex: an area that should measure at 35 SQFT is calculating at .014 SQFT).
Please advise.
Thank you!
Solved by ukdxb012. Go to Solution.
Hi Duncan,
Thank you for your quick response!
I've attached a PDF print screen to help explain.
The top screen shot is of the measured area at the Powder Bathroom (using Meaure, then Area tools).
The second screen shot shows .0141 SQFT calculated by starting my curser from the first point (upper left corner), second point (upper right corner), third point (lower right corner), forth point (lower left corner), and back to the endpoint (upper left corner). Again, it seems to work perfectly fine when I measure in the "distance" Measure tool, just not the "area" Measure tool.
I don't know what space or units I'm measuring in, as you've asked below... can you tell by my attachment? Otherwise, is this a question for our drafter who created the DWG original drawings I'm working off of?
I will be happy to give you kuddos and will be happy to accept as solution once resolved. Your assistance is greatly appreciated!
Thank you!
Duncan,
You are a genius! Clicked the "Model" tab and worked like a charm! (Of course, this was about the only tab I didn't try clicking on at first)~ simple solution which I could not find on my own, so thank you for your help.
The measurements are the same whether clicking on the 4 points or clicking on the 5th to close the endpoint.
Kuddos and thank you again!
Hi Duncan, currently i am applying your instruction with my DWG trueviewer 2013, after going to the model tab, I click the measure area icon and then proceed on clicking of the corners of the area which i want to know. still no result, the only thing that pop up is "Point or Option Keyword required".
Pleae help.
-Joseph
Hi Duncan,
I am having some trouble with the measurement tool. I do have it on the model tab when I measure an area under "area" like a small room it will show an incredibly high number like 252296 for a known area of 1200 feet. How do I get it to measure in square feet for rooms in the measurement tab? For other programs, I used the area as well
I have 2020 Trueview
