DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
TrueView 2015 Installation Error
2 REPLIES 2
knight1fox3
1269 Views, 2 Replies
Trying to install TV 2015 on a Windows 7 Professional (x64) laptop.  The following 2 errors have been experienced when attempting to install 2 different times.  Could this be a .NET issue?  The errors themselves aren't very informative as to what might be the cause.  Looking for any help/suggestions.  Thanks in advance.
2 REPLIES 2
jmcclenahan
in reply to: knight1fox3
Not sure what that error is either but I had issues getting installation to launch after files where extracted to C:\Autodesk\DWGTrueViewx64InstallImage.
I had installed from that location with previous version and I thought there may be a conflict so I deleted the C:\Autodesk folder and then ran the program again to extract the files and then the installation program started.
Might try if it sounds similar.
hazlipa
Hello @knight1fox3 !
There are a few variables that may be causing this error, the article below gives some suggestions for resolution. Could you give this a try?
Autodesk Installation Error
Let us know if you still have trouble!
Ariel Hazlip
