Trying to install TV 2015 on a Windows 7 Professional (x64) laptop. The following 2 errors have been experienced when attempting to install 2 different times. Could this be a .NET issue? The errors themselves aren't very informative as to what might be the cause. Looking for any help/suggestions. Thanks in advance.
Not sure what that error is either but I had issues getting installation to launch after files where extracted to C:\Autodesk\DWGTrueViewx64InstallImage.
I had installed from that location with previous version and I thought there may be a conflict so I deleted the C:\Autodesk folder and then ran the program again to extract the files and then the installation program started.
Might try if it sounds similar.
Hello @knight1fox3 !
There are a few variables that may be causing this error, the article below gives some suggestions for resolution. Could you give this a try?
Let us know if you still have trouble!
