I closed the command line in TRUEVIEW 2014 and don't found how to restore it.
I closed it by clicking the X (cross) button on the top of the window.
I tried all I found on the help and the forum:
CTRL-9
CTRL-0
type COMMANDLINE (although I don't think that it works with commands on the fly in trueview)
Looking at Display Options
The inline help specifies under "set interface preferences":
"Display or hide the command window by clicking Command Line on the Tools menu."
BUT... there is no Tools menu (only File, Window and Help).
Any idea?
Huh... I just found a solution.
Delete the user config:
Delete the folder
C:\Users\<USER>\AppData\Local\Autodesk\DWG TrueView 2014
After opening a new drawing everything is back as after a fresh installation.
