I closed the command line in TRUEVIEW 2014 and don't found how to restore it.
I closed it by clicking the X (cross) button on the top of the window.
I tried all I found on the help and the forum:
CTRL-9
CTRL-0
type COMMANDLINE (although I don't think that it works with commands on the fly in trueview)
Looking at Display Options
The inline help specifies under "set interface preferences":
"Display or hide the command window by clicking Command Line on the Tools menu."
BUT... there is no Tools menu (only File, Window and Help).
Any idea?
Solved by TdeBo. Go to Solution.
Huh... I just found a solution.
Delete the user config:
Delete the folder
C:\Users\<USER>\AppData\Local\Autodesk\DWG TrueView 2014
After opening a new drawing everything is back as after a fresh installation.
