DWG TrueView
DWG TrueView
New Member
joshk99
Message 1 of 1 (594 Views)
TrueView 2013 error on non-persistent desktop
594 Views, 0 Replies
06-07-2012 06:41 AM
We have a VDI system using VMWare View with floating pools. We are attempting to with the use of ProfileUnity to have all our users run from out floating pool systems for shop users. By importing on log in and log out the HKEY_CURRENT_User\Software\Autodesk tree and the Application Data and Local AppData files to not get the install everytime errors to go away but I am still running into an issue that when I launce a DWG file directly first time on a session I get a "There was a problem sending the command to the program" error but for the rest of the session they work no problems. I am guessing I am missing a reg reg but I have not been able to find the correct one and can't locate any listing of the ones required. Thanks
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
