We have a VDI system using VMWare View with floating pools. We are attempting to with the use of ProfileUnity to have all our users run from out floating pool systems for shop users. By importing on log in and log out the HKEY_CURRENT_User\Software\Autodesk tree and the Application Data and Local AppData files to not get the install everytime errors to go away but I am still running into an issue that when I launce a DWG file directly first time on a session I get a "There was a problem sending the command to the program" error but for the rest of the session they work no problems. I am guessing I am missing a reg reg but I have not been able to find the correct one and can't locate any listing of the ones required. Thanks
