DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Trueview 2013 does not install for Vista?
3 REPLIES 3
korgy
1407 Views, 3 Replies
i am sure this has been asked many times before, but i cannot find the answer.
i had TrueView 2012 on my Vista system before and it worked fine.  i installed Design Review 2013, and it said i needed TrueView 2013.  unfortunately, when i run the Trueview 2013 exe file, it does not seem to be installing completely -- no icon is installed on my desktop, and when i go back to Design review, it still tells me i need Trueview 2013.
everytime i reinstall the Trueview 2013 ex file, it says the files are already there (asks me if i want to replace them).  i dont understand.
i have heard that Tueview 2013 is not "supported" on Visat, but i have also read that it should work fine.  i tried downloading the Windows Service Pack 2, but that did not solve the problem.
anyone know the answer?
thanks
3 REPLIES 3
korgy
in reply to: korgy
do i need to install Net framework 4? is that the problem?
korgy
in reply to: korgy
apparently Net Framwork 4 was already installed -- (i just tried installing, and it asks me if i want to repair...)
Charles_Shade
in reply to: korgy
You may need to clean up all of the installs and remove the .NET4 from your system.
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Also, I would recommend REVO UNINSTALLER instead of the Windows based Change/Remove as it does a better job.
Use the Free version on it's most aggressive setting.
