DWG TrueView
DWG TrueView
Valued Contributor
mlabell
Message 1 of 13 (17,017 Views)
TrueView 2013 deployment
17017 Views, 12 Replies
03-28-2012 12:04 PM
I have downloaded the newest package with Design Review and TrueView 2013.  I am trying to automate the deployment via batch for SCCM packaging for 1400+ computers in 26 offices.  With all previous versions of the apps I have been able to run the dwgviewr.msi files, but for some reason TrueView will not allow it to be installed via the msi and only when running Setup.exe.  Am I missing something with this version?
Mark LaBell, Jr.
Technical Leader
SSOE Group
www.linkedin.com/in/marklabelljr
Valued Mentor
kevin.barnett
Message 2 of 13 (17,000 Views)
Re: TrueView 2013 deployment
03-28-2012 10:02 PM in reply to: mlabell
what is the url for the combined desgn review and trueview 2013 package?
Valued Contributor
mlabell
Message 3 of 13 (16,967 Views)
03-29-2012 04:31 AM in reply to: mlabell
Link to the install.
http://usa.autodesk.com/design-review/download/
Also if you download the TrueView only install seperately and try to deploy via the msi the same scenario happens were it requires the Setup.exe to install the application.
Mark LaBell, Jr.
Technical Leader
SSOE Group
Valued Contributor
tony_72000
Message 4 of 13 (16,964 Views)
03-29-2012 04:38 AM in reply to: mlabell
I'm seeing this as well.
I automatically deployed the MSI file, thinking it would work like the 2012 version and told the GPO to uninstall the previous version first. But when it goes to install the new version, it fails.
Now I'm stuffed? :smileyfrustrated:
The Design Review MSI works fine.
Valued Contributor
mlabell
Message 5 of 13 (16,962 Views)
03-29-2012 04:44 AM in reply to: tony_72000
Currently I am calling the ADR msi then I use the below syntax to quielty call the setup.exe for TrueView.  Not preferred (since it technically reruns ADR) but it is working in for a few installs that I need to do right away.  The other 1396 installs can hopefully wait for a better solution.
"%~dp0setup.exe" /w /qb /i %~dp0Setup.ini
%~dp0 = the relative path of the file.
Mark LaBell, Jr.
Technical Leader
SSOE Group
New Member
james.keirstead
Message 6 of 13 (16,271 Views)
04-17-2012 10:33 AM in reply to: mlabell
I have made a Transform file (.MST) available here, and also on my website at http://www.barbarianhamster.com/Services/DontRunSetup.zip
The full gory details of how it came about, and what it does, are available on my blog, http://barbarianhamster.blogspot.com
James Keirstead
http://www.linkedin.com/in/jameskeirstead/
Senior Information Systems Engineer
Perigon International, Inc.
http://www.perigoneng.com
http://www.linkedin.com/company/perigon-international-inc-/
Valued Contributor
skatterbrainz
Message 7 of 13 (16,056 Views)
04-23-2012 08:49 PM in reply to: mlabell
I've been playing around and found the following works so far pretty well...
setup.exe /Q /W /I setup.ini
Get the Visual LISP Developer's Bible 2011 Edition, and the AutoCAD Network Administrator's Bible 2012 Edition on Amazon Kindle
Distinguished Contributor
guyh
Message 8 of 13 (16,039 Views)
04-24-2012 03:26 AM in reply to: skatterbrainz
As above. I've just used "%deployment dir%setup.exe" /W /QB /I
AutoCADM 2011 SP2
Inventor Pro 2011 SP2
Valued Contributor
tony_72000
Message 9 of 13 (16,034 Views)
04-24-2012 04:19 AM in reply to: james.keirstead
This works a treat, thanks a lot.
Valued Contributor
mlabell
Message 10 of 13 (16,030 Views)
04-24-2012 04:51 AM in reply to: james.keirstead
Editing the msi did the trick! Deployment ready to roll...
echo ***Install PreReqs***
rem Do this first because some uninstalls fail because of a bad install of VCredist 2005
"%~dp0support\VCRedist\2005\vcredist_x86.exe" /q:a /norestart /c:"vcredist_x86.exe /q:a /c:""msiexec /i vcredist.msi /qn /norestart /l*v %temp%\vcredist_x86.log"" "
echo .
"%~dp0support\VCRedist\2008\vcredist_x86.exe" /q:a /norestart /c:"vcredist_x86.exe /q /norestart"
echo .
"%~dp03rdParty\DirectX\DXSETUP.exe" /silent
echo.
echo ***Removing 2010 Products***
echo ***Uninstalling ADR***
MsiExec.exe /x {55D9E026-DCB0-46FF-B60A-68B972228CF6} /passive
echo ***Uninstalling TV***
MsiExec.exe /x {5783F2D7-8028-0409-0000-0060B0CE6BBA} /passive
MsiExec.exe /x {5783F2D7-8028-0409-0100-0060B0CE6BBA} /passive
echo ***Unistall 2011 Products***
MsiExec.exe /x {8D20B4D7-3422-4099-9332-39F27E617A6F} /passive
Msiexec.exe /x {5783F2D7-9028-0409-0000-0060B0CE6BBA} /passive
Msiexec.exe /x {5783F2D7-9028-0409-0100-0060B0CE6BBA} /passive
echo ***Unistall 2012 Products***
MsiExec.exe /x {A49BDCBE-590E-43A6-AB77-7C40E499B7C1} /passive echo
Msiexec.exe /x {5783F2D7-A028-0409-0000-0060B0CE6BBA} /passive
Msiexec.exe /x {5783F2D7-A028-0409-0100-0060B0CE6BBA} /passive
echo ***Unistall ADR Plug-ins***
echo ***Uninstalling ADR DGN plugin***
MsiExec.exe /x {8F7A766B-9E2E-4895-B4B2-958D035F09B9} /passive
echo ***Uninstalling ADR JT plugin***
MsiExec.exe /x {F4C0A7CD-3A4C-4275-9CF1-9CD5136E2FE2} /passive
echo ***Install ADR 2013***
"%~dp0x86\ADR\SetupDesignReview2013.msi" /qn /norestart DEFAULTFILETYPE=dwf ADSK_DESKTOPSHORTCUT_1=0 ADR_DONOTSHOWAGAIN=1 ADR_NEXT_INITIAL_CHECK=1 PREFERENCELOCKED=1 HIDE_RESTAB=1
"%~dp0x86\DGN\SetupDesignReviewDGNImporter.msi" /qn /norestart
"%~dp0x86\JT\SetupDesignReviewJTImporter.msi" /qn /norestart
echo ***Install TV 2013 x64***
"%~dp0support\VCRedist\2005\vcredist_x64.exe" /q:a /c:"vcredist_x64.exe /q:a /c:""msiexec /i vcredist.msi /qn /norestart /l*v %temp%\vcredist_x64.log"" "
"%~dp0support\VCRedist\2008\vcredist_x64.exe" /q:a /c:"vcredist_x64.exe /q:a /c:""msiexec /i vcredist.msi /qn /norestart /l*v %temp%\vcredist_x64.log"" "
"%~dp0x64\dwgviewr\dwgviewr.msi" /qn ADSK_DESKTOPSHORTCUT_1=0
Mark LaBell, Jr.
Technical Leader
SSOE Group
