DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
TrueView 2013 deployment
12 REPLIES 12
Message 1 of 13
mlabell
18939 Views, 12 Replies
I have downloaded the newest package with Design Review and TrueView 2013.  I am trying to automate the deployment via batch for SCCM packaging for 1400+ computers in 26 offices.  With all previous versions of the apps I have been able to run the dwgviewr.msi files, but for some reason TrueView will not allow it to be installed via the msi and only when running Setup.exe.  Am I missing something with this version?
Mark LaBell, Jr.
Technical Leader
SSOE Group
www.linkedin.com/in/marklabelljr
12 REPLIES 12
Message 2 of 13
kbarnettza
in reply to: mlabell
what is the url for the combined desgn review and trueview 2013 package?
Message 3 of 13
mlabell
Link to the install.
http://usa.autodesk.com/design-review/download/
Also if you download the TrueView only install seperately and try to deploy via the msi the same scenario happens were it requires the Setup.exe to install the application.
Mark LaBell, Jr.
Technical Leader
SSOE Group
Message 4 of 13
tony_csogroup
I'm seeing this as well.
I automatically deployed the MSI file, thinking it would work like the 2012 version and told the GPO to uninstall the previous version first. But when it goes to install the new version, it fails.
Now I'm stuffed? Smiley Frustrated
The Design Review MSI works fine.
Anthony Russell
LinkedIn
Message 5 of 13
mlabell
in reply to: tony_csogroup
Currently I am calling the ADR msi then I use the below syntax to quielty call the setup.exe for TrueView.  Not preferred (since it technically reruns ADR) but it is working in for a few installs that I need to do right away.  The other 1396 installs can hopefully wait for a better solution.
"%~dp0setup.exe" /w /qb /i %~dp0Setup.ini
%~dp0 = the relative path of the file.
Mark LaBell, Jr.
Technical Leader
SSOE Group
Message 6 of 13
I have made a Transform file (.MST) available here, and also on my website at http://www.barbarianhamster.com/Services/DontRunSetup.zip
The full gory details of how it came about, and what it does, are available on my blog, http://barbarianhamster.blogspot.com
James Keirstead
http://www.linkedin.com/in/jameskeirstead/
Senior Information Systems Engineer
Perigon International, Inc.
http://www.perigoneng.com
http://www.linkedin.com/company/perigon-international-inc-/
Message 7 of 13
I've been playing around and found the following works so far pretty well...
setup.exe /Q /W /I setup.ini
Message 8 of 13
guyh
As above. I've just used "%deployment dir%setup.exe" /W /QB /I
AutoCADM 2011 SP2
Inventor Pro 2011 SP2
Message 9 of 13
tony_csogroup
This works a treat, thanks a lot.
Anthony Russell
LinkedIn
Message 10 of 13
mlabell
Editing the msi did the trick! Deployment ready to roll...
echo ***Install PreReqs***
rem Do this first because some uninstalls fail because of a bad install of VCredist 2005
"%~dp0support\VCRedist\2005\vcredist_x86.exe" /q:a /norestart /c:"vcredist_x86.exe /q:a /c:""msiexec /i vcredist.msi /qn /norestart /l*v %temp%\vcredist_x86.log"" "
echo .
"%~dp0support\VCRedist\2008\vcredist_x86.exe" /q:a /norestart /c:"vcredist_x86.exe /q /norestart"
echo .
"%~dp03rdParty\DirectX\DXSETUP.exe" /silent
echo.
echo ***Removing 2010 Products***
echo ***Uninstalling ADR***
MsiExec.exe /x {55D9E026-DCB0-46FF-B60A-68B972228CF6} /passive
echo ***Uninstalling TV***
MsiExec.exe /x {5783F2D7-8028-0409-0000-0060B0CE6BBA} /passive
MsiExec.exe /x {5783F2D7-8028-0409-0100-0060B0CE6BBA} /passive
echo ***Unistall 2011 Products***
MsiExec.exe /x {8D20B4D7-3422-4099-9332-39F27E617A6F} /passive
Msiexec.exe /x {5783F2D7-9028-0409-0000-0060B0CE6BBA} /passive
Msiexec.exe /x {5783F2D7-9028-0409-0100-0060B0CE6BBA} /passive
echo ***Unistall 2012 Products***
MsiExec.exe /x {A49BDCBE-590E-43A6-AB77-7C40E499B7C1} /passive echo
Msiexec.exe /x {5783F2D7-A028-0409-0000-0060B0CE6BBA} /passive
Msiexec.exe /x {5783F2D7-A028-0409-0100-0060B0CE6BBA} /passive
echo ***Unistall ADR Plug-ins***
echo ***Uninstalling ADR DGN plugin***
MsiExec.exe /x {8F7A766B-9E2E-4895-B4B2-958D035F09B9} /passive
echo ***Uninstalling ADR JT plugin***
MsiExec.exe /x {F4C0A7CD-3A4C-4275-9CF1-9CD5136E2FE2} /passive
echo ***Install ADR 2013***
"%~dp0x86\ADR\SetupDesignReview2013.msi" /qn /norestart DEFAULTFILETYPE=dwf ADSK_DESKTOPSHORTCUT_1=0 ADR_DONOTSHOWAGAIN=1 ADR_NEXT_INITIAL_CHECK=1 PREFERENCELOCKED=1 HIDE_RESTAB=1
"%~dp0x86\DGN\SetupDesignReviewDGNImporter.msi" /qn /norestart
"%~dp0x86\JT\SetupDesignReviewJTImporter.msi" /qn /norestart
echo ***Install TV 2013 x64***
"%~dp0support\VCRedist\2005\vcredist_x64.exe" /q:a /c:"vcredist_x64.exe /q:a /c:""msiexec /i vcredist.msi /qn /norestart /l*v %temp%\vcredist_x64.log"" "
"%~dp0support\VCRedist\2008\vcredist_x64.exe" /q:a /c:"vcredist_x64.exe /q:a /c:""msiexec /i vcredist.msi /qn /norestart /l*v %temp%\vcredist_x64.log"" "
"%~dp0x64\dwgviewr\dwgviewr.msi" /qn ADSK_DESKTOPSHORTCUT_1=0
Mark LaBell, Jr.
Technical Leader
SSOE Group
Message 11 of 13
Have any of you tried to do a silent installation (without modifying the MSI) to a different path (i.e. D:\Win32\Autodesk\.."?
Rikard Strand
Message 12 of 13
GTVic
For Design Review and DWG TrueView on Windows 7 64-bit.
Figuring out which runtime installs are required is frustrating for 2013. The following are all mentioned in this topic, various blogs, the setup.ini, etc.
Surely all of this is not required?
  • x86 Visual C++ Runtimes: 2005 SP1 ATL, 2008 SP1, 2010 SP1
  • x64 Visual C++ Runtimes: 2008 SP1, 2010 SP1
  • wmfdist64.exe, NetFx20.exe, msxml6_x64.msi
  • DirectX 9
  • DOTNET4;DOTNET4KB2468871
In the TrueView setup.ini the AOEM prerequisite is listed as:
PREREQUISITE=VCREDIST2008SP1X86;VCREDIST2008SP1X64;VCREDIST2010SP1X86;VCREDIST2010SP1X64;DOTNET20;DIRECTX;MSXML6;WMF95X64
which doesn't even mention .NET 4.0 which the readme specifically says is required including Update 1 being mandatory.
In the Design Review Installation guide it mentions VCC2010SP1x86 and .NET 4 but the ADR prerequisite in the TrueView setup.ini lists the following.
PREREQUISITE=VCREDIST2010SP1X86;DOTNET4;DOTNET4KB2468871
The main ones I would like to eliminate are:
2005 VC++, MSXML, .NET 2.0, WMFDIST
I think the reason why people are listing VCC 2005 is a prerequisite for their deployment system to work rather than for TV or ADR itself. Is that correct? I can't imagine why .NET 2.0 would be listed.
Thanks in advance.
Tags (1)
Message 13 of 13
Did you try specifying INSTALLDIR=<path> ?  For example...
setup.exe /Q /W /I /v"INSTALLDIR=D:\TrueView2013"
or (possibly)...
setup.exe /Q /W /I setup.ini INSTALLDIR=D:\TrueView2013
Tags (2)
