DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
TrueView 2012 Batch Plot not plotting DWFx format
1 REPLY 1
560 Views, 1 Reply
Getting various errors from DWFx batch plotting:
- "specified file not found" error message
- command begins, shows progress bar, then stops suddenly
- command blips progress bar, then stops suddenly
- command never executes
The funny thing is when I select the DWF format, it plots perfect.  Please post if you have had this experience, or have some ideas to fix.  Sounds like a good "hotfix" project for Autodesk.  Thanks!
1 REPLY 1
Silvia.Menon
I tested this and could batch plot to DWFx from DWG Trueview with no problems...
Does this happen only with specific files for you? Could you attach some examples?
Best regards,
Silvia
Silvia Menon
Support Specialist
Product Support
Autodesk, Inc.
http://www.autodesk.com/autocad-support
