Hi.
I'm trying to install TrueView 2011 via SCCM 2007. Have any of you guys tried this?
Everytime I try to install, it fails because DirectX isn't installed. I've tried to install DirectX separately via the following command:
DXSETUP.exe /silent
When I install it from a command prompt, it works fine, but from SCCM it never installs.
Everything else seems to be working fine.
Could someone please help me with this?
Solved by yannara. Go to Solution.
I fought with this same dxsetup silent issue in sccm for a whole week. I'll need to try this one. Will those commands you invented, create a system reboot after install?
Nope, I'm still having this error lack of Direct X during install,
Product: DWG TrueView 2011 -- Error :: Please install DirectX before installing DWG TrueView 2011.
What should I do? How Direct X could be run silently?
unfortunately not a solution but the same problem with Enteo NetInstall. Only interactive installation of DirectX seems to install it in a way, that true view setup is able to detect this properly.
Ralph
Yes, I managed to install Direct X silenty via SCCM by adding settings that user is allowed to interact. It works this way, and there is no problem.
My order for installation is:
1. Install Direct X and reboot
2. Install VCRedist 2005
3. Install VCRedist 2008 and reboot
4. Install msxml6.msi
5. Install Trueview and reboot
