I'd like to save the workspace settings of TrueView 2009, e. g. closed ribbons, so that I get a "minimal" look and feel even after restarting TrueView 2009. The problem I have is, that TrueView always switches back to default settings and I don't find a way to keep those settings...
I would appreciate any help on that.
Michael
I have tried reproducing this with DWG TrueView 2011 and it works fine - when I restart DWG TrueView and open a file, the interface settings are exactly as they were when I closed it.
Do you have the problem only in the 2009 version or in the 2011 version too?
Regards
Silvia
Silvia Menon
Autodesk Product Support
Autodesk, Inc.
I have the same problem as Mechael with DWG True View 2011. Ribbon is always closed and grid is always on. I prefer to start with open ribbon and no grid (also I have no idea how to set grid to show only intersection points, not full axis) .
Thank You in advance,
Petr
just wanted to let you know - this has been addressed in DWG Trueview 2012. You can download it from here:
http://www.autodesk.com/trueview
Best regards
Silvia
Silvia Menon
Support Specialist
Product Support
Autodesk, Inc.
http://www.autodesk.com/autocad-support
