DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
True View Educational Product Message
2 REPLIES 2
688 Views, 2 Replies
I'm trying to open a drawing from AutoCAD newer than my 2010 by first opening in TrueView, then converting. I've done this before, so I'm sure it works. In this drawing, however, I get a message that the drawing will be marked "Produced by an Educational Product" or something like that. Why is this happening?
2 REPLIES 2
pendean
The DWG file you have was created by an EDU version of AutoCAD: since that software is free for students to learn and use in school, the "prince" of free is that all DWG files are tagged with the message you received plus a print-label that shows up when you plot the file.
Realize that al content in that file carries the tag, so if you use any of it in your other files they will also be equally tagged.
It is a violation of the EDU license to use it in a commercial/for profit/for pay environment, that also includes "borrowing" content from those files to do commercial work.
Ask your file originator for details: it's between you two to resolve unless both of you are in an EDU environment of course.
in reply to: pendean
That makes sense. Thanks for the quick response. I'll bug them about
this right away.
Jack E. Cornell, PE, LEED-AP
PolyPhase Engineering, LLC
PH: 602-569-0668
