Solved by pendean. Go to Solution.
Imagine mine and the customer's frustration after telling them they could generate a CADD # based off their file name in which we knew how to remove the extension and a prefix.
We then get into Vault workflow and the published DWF (By Update or Job Processor Uses TrueView) doesn't display their CADD # for any of the prints or Web Client unless it was checked in using AutoCAD which won't be the case for the latest released copy, because the transition to Released in the lifecycle Sync's Properties and Updates the View using Job Processor.
Ridiculous!!!
I can understand the fact that the free viewer TrueView does not support this, but Autodesk uses this FREE viewer in their PAID for product like Vault Professional. Instead of using DWG TrueView to create their DWF previews in Vault, Autodesk should use AutoCAD.
