DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
True View 2014 Fails at Launch & Won't Uninstall
3 REPLIES 3
gspiper
5094 Views, 3 Replies
I have spent HOURS trying to install True View 2014 on a customer PC (new Dell Optiplex 9010 all-in-one running Win7 64-bit Enterprise) with no success.  Downloaded the 64-bit installer and install proceeded normally.  When laucnhed, the first error appeared:
Researched this and found numerous references to .Net 3.5, .Net 4.0 and C++ redistributable modules.  All of these had previously been installed on this PC and were up to date with all patches.
When I attempt to uninstall TrueView 2014, Application hangs on an "initializing" screen.
This is the buggiest installer I have worked with in years.
Anyone have a solution that will actually works ?
Glenn
3 REPLIES 3
pendean
in reply to: gspiper
No, since we don't know what your customer PC's problem may be, so you have to do a lot of work instead. This almost always works:
1. Uninstall ALL instances of .NET and C++.
2. Manually remove DTV2014 then manually clean up the WIndows Registry of Autodesk products.
3. Use a Windows Registry cleaner to tidy things up.
4. Restart Windows.
5. Reinstall DTV2014. It should inslall the support files it needs, including .NET and C++.
6. Ensure it is running corectly.
7. Start Windows Update and let it hunt for any other needed versions of .NET and C++ the other installed applications need.
selrahcnomad
in reply to: pendean
I have exactly the same problem with Trueview 2015 64 bit and this was a brand new PC with only microsoft office installed.
pendean
in reply to: selrahcnomad
Windows OS?
have you tried the 7-item list I posted earlier yet? It's not going to fix itself sadly.
