DWG TrueView
DWG TrueView
Active Contributor
jonselzer
Message 1 of 1 (254 Views)
True 2012/ Inventor 2012 DWGS not printing objects
254 Views, 0 Replies
11-21-2011 07:33 AM
Using Inventor 2012 to generate DWG's, Truview 2012 will not print the Object lines. I have tried seveal plot styles all will not print the object lines.
It is not a lineweight problem, as the border and the object lines are the same lineweight.  The files print fine from Inventor and Invnetor View.
I need Trueview to print them correctly as downstream processes do not know the difference between AutoCAD and Inventor files.
