where is all this in dwg trueview ??????
Standard File Selection Dialog Boxes
Several commands display standard file selection dialog boxes, in which you can navigate through local and network drives and through FTP sites and Web folders to select files. While each dialog box may vary slightly, following is a list of the possible options.
Files of Type
Select Initial View
Open/Save
