I have attached 3 sample drawings. I cannot see any information in Samples 1 or 2. I can only see text in Sample 3.
I believe that I could see the drawings for Sample 1 and 2 in the past and I am trying to debug what has changed. I can only see a dark gray background for Samples 1 & 2 currently.
Please see if you view any drawings in these three files.
I am currently using DWG TrueView 2011, Windows XP SP3, 32 bit. I have uninstalled and reinstalled DWG TrueView 2011 and I still cannot see anything on Sample 1 or 2.
Thanks for the reply. Even your 'repaired" files will not open on my computer with TrueView 2011. I rolled back my version to TrueView 2009 and I can open the repaired or corrupted versions of Sample 1 or 2.
I am unable to open them using TrueView as well but I am able to view the files using AutoVue v18. We have the same issue with drawings that are created or updated using Raster Design which contain the embedded TIFF Files. Any chance that this is the case for these drawings? I have investigated through the blogs and support site and there doesn't seem to be a fix for this issue anywhere.
