OK we just deployed Win 7 on computers some 64 bit most 32 bit. Some of those workstations has Trueview 2008 installed while others have 2011.
I have uninstalled the old 2008 to install the new and can not get it installed. I get to the part where it asked to run the install, i click run and then i get the below error. Not sure what the next step is to get this software installed. any help would be great. ( I'm doing this as Admin on the Box) most work fine. I just have 2 right now cause me headaches,,,,,
SetupDWGTrueView2011_32bit.exe - Application Error The application was unable to start correctly (0xc0000005). Click OK to close the application.
Hi, I had the same problem and finally I found a really easy solution, I used WinRar to extract all files in the .exe file to a new folder and then I installed the aplication from there.
Bye
