DWG TrueView
DWG TrueView
New Member
Hayleigh128
Message 1 of 5 (724 Views)
Saving Drawing Layers as Individual Files
724 Views, 4 Replies
02-01-2013 03:53 AM
I am new to TrueView and wondered if I could get some advice?
I have a drawing with 30 layers. I want to save each individual layer as a drawing.
Can I do this in TrueView? Or do I need CAD??
I want to save them as drawing because later I want to go back through and take dimensions of the pipes (which I cant do if I plot them to PDF).
Thanks in advance.
Charles_Shade
Message 2 of 5 (721 Views)
Re: Saving Drawing Layers as Individual Files
02-01-2013 04:45 AM in reply to: Hayleigh128
There is the ability to Freeze and Turnoff layers.
You could go thru and do one or the other to each drawing and save it with only those Layers you want visible.
Too bad Layer Isolate (LAYISO) is not avaialble in the Menu as that would be a quick way to do this.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
New Member
Hayleigh128
Message 3 of 5 (716 Views)
02-01-2013 07:34 AM in reply to: Charles_Shade
Sounds great, thanks!!
One further question.... How do I save as a DWG with a different title when I have tuned off the layers I don't want to show?
The only options I seem to have are Convert, Plot and Batch Plot?
I noticed I can plot to file but none of the file types are DWG.
Thanks again.
Charles_Shade
Message 4 of 5 (707 Views)
02-01-2013 09:41 AM in reply to: Hayleigh128
Yep I think that would be the limitation to your quest.
Where are you getting these Drawing Files?
Charles_Shade
Message 5 of 5 (700 Views)
02-01-2013 10:45 AM in reply to: Charles_Shade
You can export to DWF and use Autodesk Design Review to measure.
Though this is getting to be a chore at this point in something that should be easy.
