DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Rotating a drawing
9 REPLIES 9
Message 1 of 10
8886 Views, 9 Replies
Rotating a drawing
Is there a way to see exactly what angle a 3D drawing has been rotated to?  I'm attemtping to rotate multiple drawings but I want them to be at the same angle.
9 REPLIES 9
Message 2 of 10
Charles_Shade
Is this in DTV or another Autodesk product?
Message 3 of 10
in reply to: Charles_Shade
Yes it is in DTV.
Message 4 of 10
Charles_Shade
Best I can tell the most you can do is use the Presets that are available under the dropdown View, Named Views, Preset Views.
In Help this is Views, 3D views for more information
Message 5 of 10
So there is no way to rotate to my preferred angle and then save that as a preset?
Message 6 of 10
Charles_Shade
Not that I see.
DTV is very limited and only meant to view a drawing. User input does not have much sway there.
Message 7 of 10
Would there be a way for me to do it if I had AutoCad?
Message 8 of 10
pendean
yes.
Message 9 of 10
Okay so how would I go about creating my own custom rotation setting in AutoCAD?
Message 10 of 10
pendean
UCS command.
https://www.google.com/#q=rotate+a+drawing+in+autocad
or
DVIEW command, TWIST option.
https://www.google.com/#q=how+to+use+dview%27s+twist+option
Experiment, find out which one works best for your needs, if you get stuck anywhere post back with details on what you've chosen to do and how you went about it.
