DWG TrueView
Active Member
sjlundin29
Message 1 of 10 (683 Views)
Rotating a drawing
683 Views, 9 Replies
09-03-2013 01:01 PM
Is there a way to see exactly what angle a 3D drawing has been rotated to?  I'm attemtping to rotate multiple drawings but I want them to be at the same angle.
Charles_Shade
Message 2 of 10 (675 Views)
Re: Rotating a drawing
09-03-2013 06:09 PM in reply to: sjlundin29
Is this in DTV or another Autodesk product?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Active Member
sjlundin29
Message 3 of 10 (658 Views)
09-05-2013 07:02 AM in reply to: Charles_Shade
Yes it is in DTV.
Charles_Shade
Message 4 of 10 (654 Views)
09-05-2013 07:13 AM in reply to: sjlundin29
Best I can tell the most you can do is use the Presets that are available under the dropdown View, Named Views, Preset Views.
In Help this is Views, 3D views for more information
Active Member
sjlundin29
Message 5 of 10 (628 Views)
09-10-2013 07:30 AM in reply to: Charles_Shade
So there is no way to rotate to my preferred angle and then save that as a preset?
Charles_Shade
Message 6 of 10 (607 Views)
09-11-2013 12:11 PM in reply to: sjlundin29
Not that I see.
DTV is very limited and only meant to view a drawing. User input does not have much sway there.
Active Member
sjlundin29
Message 7 of 10 (605 Views)
09-11-2013 12:21 PM in reply to: Charles_Shade
Would there be a way for me to do it if I had AutoCad?
pendean
Message 8 of 10 (600 Views)
09-11-2013 12:57 PM in reply to: sjlundin29
yes.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
sjlundin29
Message 9 of 10 (572 Views)
09-12-2013 10:07 AM in reply to: sjlundin29
Okay so how would I go about creating my own custom rotation setting in AutoCAD?
pendean
Message 10 of 10 (569 Views)
09-12-2013 01:03 PM in reply to: sjlundin29
UCS command.
https://www.google.com/#q=rotate+a+drawing+in+autocad
or
DVIEW command, TWIST option.
https://www.google.com/#q=how+to+use+dview%27s+twist+option
Experiment, find out which one works best for your needs, if you get stuck anywhere post back with details on what you've chosen to do and how you went about it.
