Is there a way to see exactly what angle a 3D drawing has been rotated to? I'm attemtping to rotate multiple drawings but I want them to be at the same angle.
Is this in DTV or another Autodesk product?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Best I can tell the most you can do is use the Presets that are available under the dropdown View, Named Views, Preset Views.
In Help this is Views, 3D views for more information
Not that I see.
DTV is very limited and only meant to view a drawing. User input does not have much sway there.
UCS command.
https://www.google.com/#q=rotate+a+drawing+in+autocad
or
DVIEW command, TWIST option.
https://www.google.com/#q=how+to+use+dview%27s+twist+option
Experiment, find out which one works best for your needs, if you get stuck anywhere post back with details on what you've chosen to do and how you went about it.
