DWG TrueView
Member
simon2505
Message 1 of 8 (749 Views)
Problems installing DWG true view
749 Views, 7 Replies
09-11-2013 09:30 AM
I installed true view
it asked for .NET 4 and then 3.5
installed them and successfully installed the true view.
But now when I try to open the true view it gives me this message (Attached)
does anyone have an idea how to solve this?
*Expert Elite*
pendean
Message 2 of 8 (738 Views)
Re: Problems installing DWG true view
09-11-2013 11:27 AM in reply to: simon2505
Did you try #1?
What is the answer to #2?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
simon2505
Message 3 of 8 (732 Views)
09-11-2013 12:45 PM in reply to: simon2505
1. I have installed and removed it quite a few times
2. No idea why it is "saying" that.
This is why I turned for help here...
*Expert Elite*
pendean
Message 4 of 8 (727 Views)
09-11-2013 12:56 PM in reply to: simon2505
Do you have any other Autodesk products installed?
Which DTV version did you try and install?
Your Windows version?
Member
simon2505
Message 5 of 8 (722 Views)
09-11-2013 01:27 PM in reply to: pendean
I dont have any other autodesk products installed
Soory, but what is DTV?
windows 7, 32bit.
*Expert Elite*
Charles_Shade
Message 6 of 8 (717 Views)
09-11-2013 02:10 PM in reply to: simon2505
Drawing True View
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Member
simon2505
Message 7 of 8 (714 Views)
09-11-2013 02:32 PM in reply to: Charles_Shade
true view 2014
*Expert Elite*
pendean
Message 8 of 8 (672 Views)
09-12-2013 05:52 AM in reply to: simon2505
Remove all .NET and Visual C++ versionf on your PC.
Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
Restart your PC.
Turn off all background running applications: all of them.
Install DTV2014.
Remember to start Windows Update to put back .NET and Visual C++ versions that may be neded by other applications on your PC.
Post to the Community
New Post
Need installation help?
