DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Problems installing DWG true view
7 REPLIES 7
Message 1 of 8
1116 Views, 7 Replies
I installed true view
it asked for .NET 4 and then 3.5
installed them and successfully installed the true view.
But now when I try to open the true view it gives me this message (Attached)
does anyone have an idea how to solve this?
7 REPLIES 7
Message 2 of 8
pendean
Did you try #1?
What is the answer to #2?
Message 3 of 8
1. I have installed and removed it quite a few times
2. No idea why it is "saying" that.
This is why I turned for help here...
Message 4 of 8
pendean
Do you have any other Autodesk products installed?
Which DTV version did you try and install?
Your Windows version?
Message 5 of 8
in reply to: pendean
I dont have any other autodesk products installed
Soory, but what is DTV?
windows 7, 32bit.
Message 6 of 8
Charles_Shade
Message 7 of 8
in reply to: Charles_Shade
true view 2014
Message 8 of 8
pendean
Remove all .NET and Visual C++ versionf on your PC.
Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
Restart your PC.
Turn off all background running applications: all of them.
Install DTV2014.
Remember to start Windows Update to put back .NET and Visual C++ versions that may be neded by other applications on your PC.
